Memphis 16-pr1x1000 help - Page 6 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 17th June 2017, 06:58 PM   #51
Should all 8 of my outputs be the same dc? I have 4 showing 4.19v with resisted current the other for are showing -14.2 v. I am wondering if this is normal or do I have one of those chips backwards.
Old 18th June 2017, 12:11 AM   #52
The page from where you purchased the ICs had a datasheet. The datasheet identifies pin 1. Pin 1 goes to the white dot. I didn't think answering this question was necessary since I didn't see it until after you stated that you installed them.
Not knowing where you had your probes (black and red and if relevant, on which terminals of which IC), it's impossible to use the voltages that you posted.
Old 18th June 2017, 12:24 AM   #53
Thats how I installed them. Ok so the amp powers up, I get 1-3 of all outputs 3.00v.
Old 18th June 2017, 12:28 AM   #54
On pin 1 q103 I get 7.03v on pin 1 of q108 -12.21v I was concerned since I had used a replacement chip based on the data sheet.
Old 19th June 2017, 03:43 AM   #55
so with limited current everything appeared ok so when i tried to power it up it blew a ten amp fuse?
Old 20th June 2017, 03:19 PM   #56
Did any outputs fail?
Old 20th June 2017, 07:34 PM   #57
With the resisted current I have 1-3 a consistent 3.01v on all outputs. Is this smd correct Perry on q111, it seems odly placed is all. How should I test them in circuit. Or should I remove the gate leg
Old 20th June 2017, 08:39 PM   #58
This is a photo of the same model but it's not the same as yours. For example, R178 is missing in your amp and doesn't appear to have been installed. As you can see, there is a trace in place of the resistor on Q111.
http://www.bcae1.com/temp/IMG_2104.JPG
These are the parts that failed when the outputs failed on one amp I repaired. Check them (mainly regulator and resistor) in your amp.
http://www.bcae1.com/temp/IMG_2100bnotes.jpg
Will the amp produce audio with the limiting resistor in place?
Old 20th June 2017, 08:41 PM   #59
Ok will do thanks again Perry. No it does not produce audio audio.
Old 21st June 2017, 01:03 AM   #60
Also it appeared to be burnt or charred around q111, not sure if it relevant or not. And check those components.
Memphis 16-ST3004 Outerlimits Car Audio 8 12th June 2013 04:52 AM
Memphis Pr1x1000 jordan_ciaramit Car Audio 8 12th January 2013 02:07 AM
Memphis 16-MCH1300 help scotts530 Car Audio 70 16th March 2012 10:46 AM
Memphis 16-ST1500D Dr Zeus Car Audio 3 15th January 2012 10:27 PM
Memphis 16-st1000d mike49504 Car Audio 46 19th May 2010 07:40 AM
Copyright 1999-2017 diyAudio
