Cadence CPA245
Cadence CPA245
Old 19th May 2017, 03:54 PM   #1
Frycztech is offline Frycztech
Default Cadence CPA245
Someone gave me this amp a while ago and Iam trying to learn more and fix it so it was missing a fuse and I put a fuse back into it and tried to power it off my power supply and the light on the supply shuts off when its connected. So I believe that there is a short. Any help would be appreciated!
Old 19th May 2017, 04:23 PM   #2
Perry Babin is offline Perry Babin  United States
If the excessive current draw is only after remote voltage is applied, the output transistors are the most likely culprit.
Old 19th May 2017, 04:59 PM   #3
I just checked it happens as soon as I connect the battery terminal
Old 19th May 2017, 05:01 PM   #4
That would likely be either shorted power supply FETs or a shorted reverse protection diode. If the FETs don't read near 0 ohms from leg 1-2, it's likely the reverse protection diode.
Old 19th May 2017, 05:08 PM   #5
So the oiwer supply FETs would be the 2 IRFZ44 at the top right? And leds 1 and 2 would be the gate and drain?
Old 19th May 2017, 06:54 PM   #6
yes and yes
Old 19th May 2017, 06:58 PM   #7
The top FET has 7.5ohms the other has 191ohms
Old 19th May 2017, 07:09 PM   #8
Pull them and check them out of the circuit. They're likely defective.
Old 19th May 2017, 07:43 PM   #9
One has 8ohms between 1 and 2 and the other is showing it is open.
Old 19th May 2017, 07:50 PM   #10
The open one may be OK but you should replace both. After cleaning the pads so there is no solder bridge, does it draw excessive current when powered up?
Cadence CPA245Hide this!Advertise here!
cadence ian33 Car Audio 23 28th September 2015 05:14 AM
Cadence TXA6004 Repair whitejohnny Car Audio 8 26th August 2012 07:41 PM
Cadence SUB manoli337 Subwoofers 2 4th July 2012 08:18 PM
Enclosure for Cadence Speakers rjuan Construction Tips 3 28th May 2012 09:35 PM
cadence amp hitman1 Car Audio 9 19th May 2011 06:33 AM
