I need to run 2 RCA cables between radio (dashboard) and 2-channel amplifier (trunk). I have a shielded cable with 2 conductors (20 AWG). Can I use this instead of 2 separate cables? The shield will be shared between L and R. Will there be a crosstalk (?) between 2 inner conductors?
Thank you.
Thank you.
This seems the same as a shielded twisted pair (STP).I need to run 2 RCA cables between radio (dashboard) and 2-channel amplifier (trunk). I have a shielded cable with 2 conductors (20 AWG). Can I use this instead of 2 separate cables? The shield will be shared between L and R. Will there be a crosstalk (?) between 2 inner conductors?
Thank you.
In an STP cable, one uses the internal pair to transfer the signal, i.e. one of the pair is Signal Flow/Hot and the other is the Signal Return/Cold. The Shield is connected to the chassis/enclosure at each end.
For two channels one needs two STP.
