hello there need some advice for driver board ( somehow similar to DWM1216) but these have H-bridge IC drivers soic-14By International Rectifier IRS21844S perhaps?? , have make a research but can't find anyone to fit the leads function, any kind of help will be highly appreciated https://drive.google.com/open?id=0B5iEUviWbCAZQTY3by1EOGhJUUk
https://drive.google.com/open?id=0B5iEUviWbCAZcGQxQ0RfN09RRk0
http://www.infineon.com/dgdl/irs2184.pdf?fileId=5546d462533600a401535676d8da27db
it uses 2 LM7812 one per each 2 IR21844S, and both measures are fine on the main board without the driver board, just for make sure think i will replace those too , thanks again Perry.The 12v regulator is common to all of the drive ICs and when one IC fails, it destroys the regulator and the other driver ICs. Have you confirmed that the regulator and the other ICs survived?
