Xtanat 1000.1
Xtanat 1000.1
Old 20th March 2017, 06:30 AM   #1
seankane is offline seankane  United States
seankane's Avatar
Default Xtanat 1000.1
Anyone have a schematic for these amps?
Its an Xtant X1001
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 20th March 2017, 09:02 AM   #2
Perry Babin is offline Perry Babin  United States
I don't think that I've ever seen an xtant diagram. What's the problem?
Old 21st March 2017, 06:16 AM   #3
seankane's Avatar
The amp powers up with about 20-25 amps of current draw until caps charge, the idles at about 1.5 amps. I see no LED lights lit and there is no sound output.
Old 21st March 2017, 01:05 PM   #4
Do you have rail-rail oscillation on the output transistors?
Do you have positive and negative rail voltage?
Do you have positive and negative supply voltage on the op-amp power supply pins?
Old 28th March 2017, 05:08 AM   #5
seankane's Avatar
I have +75/-75 volts rail
I have no positive or negative regulated voltage to any op-amps.
I see positive regulated at a few of the devices on the board but no negative. Where is the negative regulator?
I'm not sure why the pos/neg regulated is not making it to the op-amps?
Old 28th March 2017, 06:37 AM   #6
Do you see any square wave signals or DC on the SMD diodes near the small yellow transformer near the speaker terminals?.
Old 29th March 2017, 03:09 AM   #7
seankane's Avatar
No square wave, and nothing over .333 vdc
Old 29th March 2017, 03:15 AM   #8
There are 4 0.22 ohm resistors near the clamps for the power supply transistors. Are they within tolerance (they may be in parallel)?
Old 29th March 2017, 05:21 AM   #9
seankane's Avatar
2 read 000.4 ohm
1 reads open 0.L
1 reads 1 ohm
Old 29th March 2017, 06:08 AM   #10
Replace the ones out of tolerance. If you don't have exact replacements, use emitter resistors temporarily.
Xtanat 1000.1Hide this!Advertise here!
$1000! How best spent? bullpeters Analogue Source 11 3rd June 2012 02:09 PM
xtant 1000 timwebb Car Audio 9 24th May 2010 07:35 PM
memphis 1000 mike49504 Car Audio 43 13th January 2010 05:34 PM
Best 7.1 Amp for under 1000 martin01p Solid State 1 28th August 2008 03:22 PM
Panamax 1000+ eds65gto Everything Else 1 14th April 2005 10:10 PM
