Audio driver board
Audio driver board
Old 3rd March 2017, 11:15 AM   #1
luigidedom is offline luigidedom  United Kingdom
Default Audio driver board
On these boards which resistor is changed to make protection less sensitive
Old 3rd March 2017, 12:00 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Circuit?
Make?
Model?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 3rd March 2017, 01:17 PM   #3
Perry Babin is offline Perry Babin  United States
R30
Old 3rd March 2017, 06:53 PM   #4
Sundown 3500
Old 3rd March 2017, 06:55 PM   #5
Perry, Increase or decrease value of R30?
Old 3rd March 2017, 06:58 PM   #6
Are you sure that you want to make the protection circuit less effective?
If you lower the value, the threshold for shutdown will be lower (it will shut down sooner). Increase the value to make the amp less reliable.
Old 4th March 2017, 03:08 AM   #7
The amp is being used purely for spl it shutting down just before the end of the roll so just need to increase that threshold. R30 on this amp is 3k9 I see on some other similar boards its 4k7
Old 4th March 2017, 03:43 AM   #8
390, not 3.9k
Old 4th March 2017, 04:27 AM   #9
Side note... The resistor value AND the shunt resistor value determine the shutdown. You cannot compare the value of R30 to other amps unless they use the exact same shunt resistors. Even then, if the output configuration and rail voltage are different, the value of R30 may be different.
Increasing its value will do what you want but you should tell the owner that here is a risk of much greater damage if/when the outputs fail.
Old 5th March 2017, 05:02 AM   #10
Correction yes 390 and 470 and yes the owner is aware of the consequences. I have told him to check the impedance at the frequency and that his box or port is more than likely the problem and not the amp. But you know these spl guys know it all when it comes to box design......
Audio driver boardHide this!Advertise here!
Hifonics audio driver board seankane Car Audio 32 14th September 2015 11:13 AM
Curcio Audio Dynaco Mk3 Driver Board Altecboy Swap Meet 2 2nd October 2014 08:56 PM
Digital design audio driver board megael9 Car Audio 0 14th August 2014 03:44 AM
jl audio 300/4 driver board flashing Triviumfan4 Car Audio 11 2nd May 2014 04:34 AM
Incriminator Audio 40.1 Output Driver Board amp it up Car Audio 2 17th February 2014 08:35 PM
