#241 | |
When the load on the transformer secondary is increased the reset current through the primary windings increases when they fly low. The result is that the core flux resets faster, getting closer to zero magnetism before the dead time period expires. Well, that way is how I understand things, anyway. If the problem is not critical in your application, the answer would be to make sure the core has enough ventilation. Otherwise, you could reduce the duty cycle at low power output which would increase the flyback current through the primaries, as well as providing more dead time for the core to demagnetize. But then the output choke becomes more important and a feedback circuit becomes necessary.
USMPS http://groups.yahoo.com/group/switchmode/ |
#242 | |
1) Use a bigger core 2) Use a pulse-by-pulse current mode controller |
#243 |
Even simpler :
Increase turn counts and/or add something like 10% dead time Also check for symmetry the pulses generated by the controller IC. I've found some SG3525 units from SGS-Thomson to produce asymetric pulses EMI feedback into the IC signal paths may also cause asymetric pulses |
#244 |
or do a better job of winding the turns -- you could use a small computer fan to cool the core --
i really think that this discussion gets very complex for a bulletin board -- sanjay at National Semi has done a really good job of explaining the route to optimization -- again search "magnetics" on their website . With a core you pull out of a hamfest grab-bag it's difficult, but not impossible, to get really good results -- but you have to characterize aspects of the core so that you can apply the design equations. |
#245 |
I think the best advice anybody could give on smps is to push aside one"s linear attitude or knowhow aside for the moment and master the ferrite and is principles.
Honestly, that is what I am doing for the main time and that is what Eva and the smps guru did. BWG, pls conquer the ferrite and you will be surpriced. soundbag. _________________ "DONT TRUST ANYMAN, MEASURE EVERYTHING"
soundbag |
#246 |
This seems to be new on National Semi's "Power Bench" website, a reading list for prospective SMPS designers:
http://www.national.com/appinfo/powe...68,319,00.html btw, I have been adding links to resources I find helpful at: www.tech-diy.com/smps.htm jack |
#247 |
I red your many thread replly. really you are very knowledgeable person. I want to build a SMPS from this thread Making car amplifier SMPS with tl494 + DC Protection But problem that i did not find any toroid in my city. i found a ETD 39 transformer . Can you tell me how to winding a ETD transformer? i want to use for 34 vols output transformer for this SMPS. Let me know how meny AWG wire i have to use? How many turn i have to use for primary and secondary? I did not send mail directly to u, sorry for write to u from this thread regards Robin |
#248 |
I am sorry that my last reply (Post #247 ) was for 'Eva'. sorry again for my mistake. I was forgeted to mention her name.
But any one can help me pls. Regards Robin |
#249 |
Robin, I have done a lot with the ETD series of cores. First make sure you have an UNGAPPED core! Hold the two halves together and look at a light source through the joint of the middle legs. You should not see any light. There are also different ferrites available in the same core shape. The H7C ferrite is the one you want for smps.
Eight turns center tapped for the primary and 12 or thirteen turns center tapped for the secondary. For the primary, I would use the equivalent of #10 wire and for the secondary, #12. There should be plenty of window space for the wire on the bobbin. I would recommend using a Litz type wire or at least several smaller wires in parallel for the windings. Aside to Eva, A woman who speaks smps, ...... I Love you Best regards, Steve
Finding new ways for the extreme mis-application of high tech! |
#250 |
Hi to all,
i am building my first smps from project 89. I wound my transformer(just primary), and have a question. My ferite core(permeability is 2000) is 29mm inner diameter, 45mm outer diameter and 8mm height and width. I wound my primary with double solid cooper wire (2mm diam. each). Maybe anyone can look at my work and coment if i do this right? What power rating can i expect from this transformer? primary winding thanks
Dainius |
| toroid ID help | BeerCan | Power Supplies | 2 | 25th May 2011 12:38 AM |
| Toroid or EE Ferrite core, which is Best for 240V mains SMPS | Workhorse | Power Supplies | 49 | 6th February 2007 07:44 PM |
| Trade a 40V 400VA Toroid for 20V 300VA Toroid | john65b | Swap Meet | 7 | 10th October 2006 04:49 AM |
| SMPS toroid transformer question | thoriated | Power Supplies | 11 | 6th April 2006 03:13 AM |
| Page generated in 0.13815 seconds (82.21% PHP - 17.79% MySQL) with 11 queries |
