Go Back   Home > Forums > General Interest > Car Audio
Old 14th August 2004, 11:13 PM   #231
B.I.G is offline B.I.G  Romania
jackinnj so you are saying that even in a grounded case the RF can still get out
My smps is in a computer PSU case
B.I.G
Old 14th August 2004, 11:31 PM   #232
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
A grounded metal case provides decent attenuation to electric fields [capacitive propagation of quick voltage changes] but attenuation to magnetic fields [inductive propagation of quick current changes] may pass through the case with 20dB or less attenuation
Also, the case does nothing against EMI radiated through the input and output wires acting as antennas
Old 14th August 2004, 11:38 PM   #233
i can hear it with the radio at LW ... it is not loud but it exists ..... i`ve lost the top cover from the PC psu so i can not test it in the case (((
B.I.G
Old 14th August 2004, 11:47 PM   #234
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
imho if u can hear it then there is something wrong allready
Old 14th August 2004, 11:55 PM   #235
Sheriff is offline Sheriff  United Kingdom
Sheriff's Avatar
Send a message via ICQ to Sheriff Send a message via MSN to Sheriff
Default What makes a good smps?
What in your experience makes a good SMPS for audio use.
Looking at an off line converter -
Active PFC with more than enough 'C' to cover low line worst case?
Good LF gain?
tightest regualtion at the output?
loop response that covers the audio bandwidth?
Transient response?
Low output noise?
etc.
Just looking form some parameters and what benefots they offer over a traditional linear PSU for use in a domestic amplfiier
Cheers
Sheriff
Sheriff
Old 15th August 2004, 12:14 AM   #236
subwo1 is offline subwo1  United States
subwo1's Avatar
Originally posted by jackinnj
... what will mystify you even with a spice model is the compensation for the comparator/error amplifier --
I have simulated my design of a SMPS because it is a very simple circuit theoretically. I know it is not perfect, but I have not found an approach I like more, even in real life. That circuit definitely shows the benefits of phase compensation in the feedback loop. I think that concept is what you mean.
USMPS
http://groups.yahoo.com/group/switchmode/
Old 15th August 2004, 12:25 AM   #237
subwo1's Avatar
Default Re: What makes a good smps?
0f
I feel that for DIY passive is more than sufficient, and much simpler, with no added interference.
USMPS
Old 15th August 2004, 12:38 AM   #238
Sheriff's Avatar
Default smps and class d
Hi Subwo1,
How about the pros / cons compared to a linear PSU powering a class D amp for example.
I know you have much experience on this topic also.
I guess that with a bit of messing around you could sync an active PFC stage to the downconverter to a multiple of the Class D amps switching frequency in an atempt to avoid beat frequencies.
The trouble is developing a good amplifier with a fixed carrier frequency....., and then filtering the sync'd noise...
Cheers
Sheriff
Old 15th August 2004, 12:55 AM   #239
jackinnj's Avatar
Originally posted by sss
yeah but when u put the sub circuit into the whole smps circuit the computer barely moves and the whole thing makes stupid software errors
then you need better software -- GIGO
Old 15th August 2004, 01:14 AM   #240
subwo1's Avatar
Hi Sheriff,
Reality turns out to be not much more than a bunch of trade-offs. I try not speak on the issue of the best approach for any one individual, unless they already have a set course I can give advice I am comfortable with.
I did tinker with an unregulated SMPS which also was the source of the constant switching frequency of an amp. But other projects needed attention and I did not return to experimenting with the circuit.
USMPS
toroid ID help BeerCan Power Supplies 2 25th May 2011 12:38 AM
Toroid or EE Ferrite core, which is Best for 240V mains SMPS Workhorse Power Supplies 49 6th February 2007 07:44 PM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 04:49 AM
SMPS toroid transformer question thoriated Power Supplies 11 6th April 2006 03:13 AM
Page generated in 0.12318 seconds (79.62% PHP - 20.38% MySQL) with 11 queries
