JL 600/1 v3 failure
JL 600/1 v3 failure
Old 5th December 2016, 09:11 PM   #21
Perry Babin is offline Perry Babin  United States
The scope should be grounded to the negative terminal of the 12v power supply.
Did you apply remote then remove it after a few seconds and then check the gate pads within the next 10 seconds?
Old 5th December 2016, 09:52 PM   #22
dhillman is offline dhillman
Yes, That is what I did several times. I also attached the ground cable of the Oscilloscope to the negative of my 12v power supply. The first pad 504 was about 14v I believe, but the next was 0 and if I wait to the end it will jump momentarily to about 4v. The 3rd was like double the first, and the last one was 0 even at the end of the cycle. I will repeat the test tonight with more precise information.
I never used the alligator clip because I attached the cable to the ground of the Oscilloscope and to the neg of the power supply.
I've never seen a sinusoidal wave with this Oscilloscope. I think the defective part of the unit is the one behind the unit (means ME). I may not be using it correctly.
Thank you again, I hope the drivers and the Pulse width modulated are ok.
Darrel
Old 5th December 2016, 09:58 PM   #23
I don't know if your board will be the same as the one below. If it is, solder a bridge between the two pins in the orange circle and try looking for the signals again.
You MUST remove the jumper before powering the amp up with the outputs in the circuit.
Old 6th December 2016, 03:49 PM   #24
Thanks Perry for your help. With the trace adjustment the tilted display is back to normal with the Hitachi. I couldn't get the square wave in any of the pads. After jumping the chip shown in the pervious photo, I got a square wave with 2.97 volts at Q504 and Q507. Q505 showed a distorted band in the display, which I was unable to adjust to get some kind of wave. Q506 showed a square wave with 4.95vdc.
Would you say that the PWM and driver transistors for the output are ok? Would I need to just change the output transistors as well as the power supply transistors? So far the circuit board had been the same as the JL500/1/
Thank you again.
Darrel
Old 6th December 2016, 04:45 PM   #25
Post a photo of the waveform on Q505.
Old 6th December 2016, 05:05 PM   #26
Ok I will do that tonight. What would happen if I let the unit in the ON mode to see if I can adjust the Hitachi to get a wave form from Q505? I get about 10 secs. or less before the current stop. With the adjustment I used to see the wave of Q504 and 507, I get a thick band about 1 volt with different densities vertically. I will also measure the dcv at that pad, which I haven't done.
I notice I needed a lot of heat to remove the transistors. Those are soldered to huge bar of aluminum and copper on the board. Do you still use the WIS50 for that application?
Thank you Perry, will keep in touch.
Darrel
Old 6th December 2016, 05:13 PM   #27
They come out easily with the WES51. If there are no burrs on the legs of the transistors, apply enough new solder and lay the iron across all 3 legs. When all are hot (solder molten), they will fall out or can be pulled out with very little force.
I generally do it as I suggested because it prevents the main supply from switching on. If there are no power supply FETs in the amp, I think it will work if you leave the remote attached.
Try adjusting the trigger level and trigger coupling.
Old 6th December 2016, 11:19 PM   #28
Got all square waves. Vdc varies though, when measured with a digital multimeter. Images for each gate leg attached from Q504 to Q507.
Tell me what you think, would you say the variation in voltage is an instrument problem?(square wave measured in dc) or is there something wrong with the transistor drivers?
Please reply, and thank you for your help.
Darrel
Old 6th December 2016, 11:33 PM   #29
Earlier, you stated that there were discolored resistors. Were they within tolerance?
Do the waveforms on pins 5 and 7 of U500 look the same? To prevent shorting pins together, it may be easier to touch the probe to R514 and R515 (the ends directly connected to pins 5 and 7 -- confirm connection with ohm meter with no power applied)
Old 6th December 2016, 11:57 PM   #30
Q504 to Q507
JL 600/1 v3 failureHide this!Advertise here!
HD 600/4 JL ian33 Car Audio 7 8th June 2016 07:12 AM
amp stopped working (jl 600/1v2) 4x4audio Car Audio 15 16th November 2015 12:34 AM
JL Audio HD 600/4 S Merlington Car Audio 12 9th April 2015 08:39 AM
jl audio hd 600/4 issue with rear left channel srsotor Car Audio 3 22nd January 2015 10:43 AM
A300HLX Amp 600 Watt JL Audio Sub Maxcloud Car Audio 2 30th April 2008 12:02 AM
