JL 600/1 v3 failure
JL 600/1 v3 failure
Old 1st December 2016, 07:12 PM   #11
Perry Babin is offline Perry Babin  United States
Try the ones you ordered. They may work. The 540s were reliable. I used the IRF3415 plenty of times as well as the IRF3710Z.
Old 1st December 2016, 09:09 PM   #12
dhillman is offline dhillman
Thank you, 1 of the 47 ohms surface mount resistance changed in color. How do I test the U500? Or is it better to replace it? Thank you again!
Darrel
Old 1st December 2016, 09:56 PM   #13
Do you have or have access to an oscilloscope?
Old 1st December 2016, 11:33 PM   #14
Yes I do!
Old 2nd December 2016, 06:29 AM   #15
With the output FETs out of the board, connect two jumpers as shown below. Apply remote and after a couple of seconds, remove remote voltage and check the signal on pad 1 for all 4 of the outputs. There should be a square wave for about 10 seconds after removing remote voltage.
The power supply FETs don't have to be in the circuit.
Set the scope to 5v/div, DC coupling and 5us/div. Align the trace to the reference line before checking the waveforms.
Old 2nd December 2016, 08:24 PM   #16
Thank you, when you say output, you are talking about the gate for each FET?
Thank you, I will try this tonight.
Darrel
Old 2nd December 2016, 08:34 PM   #17
Yes
Old 5th December 2016, 11:39 AM   #18
Well I read several times the section on the oscilloscope at your website. This is not exactly my terminology. I have a Hitachi V-252 with a slanted display. I think it fell off. Q504(pad 1)- 14v, Q505- 0v then at the end 4v, Q506- 28v, Q507- 0v. I never saw a square wave. I think that was either my set-up or the instrument.
If you notice any huge mistake in what I'm doing, please let me know. Where should I attach the alligator clip?
Thank you again.
Darrel
Old 5th December 2016, 04:32 PM   #19
There is a trace rotate adjustment on the scope. Find it and set the trace straight. Magnets will also cause it to rotate/shift.
Old 5th December 2016, 07:36 PM   #20
Thank you Perry. Would you say the Chip at the U500 is bad? Why do I have this different readings from each pad? Could it be the driver transistors? What is the driver voltage at the gate of each transistor? Do they run in parallel for each channel?
I will try to get readings with some attached images to check on this chip.
Thank you
Darrel
JL 600/1 v3 failureHide this!Advertise here!
HD 600/4 JL ian33 Car Audio 7 8th June 2016 07:12 AM
amp stopped working (jl 600/1v2) 4x4audio Car Audio 15 16th November 2015 12:34 AM
JL Audio HD 600/4 S Merlington Car Audio 12 9th April 2015 08:39 AM
jl audio hd 600/4 issue with rear left channel srsotor Car Audio 3 22nd January 2015 10:43 AM
A300HLX Amp 600 Watt JL Audio Sub Maxcloud Car Audio 2 30th April 2008 12:02 AM
