Do not worry Perry, forget my last question.
Then, finishing:
That waveform, must be normal in this amplifier ...
I checked that waveform by directly connecting the test probe between the gate and the source, and the result is the same.
Do you think I can install D11 in the power supply?
Then, finishing:
Installed D11 and the voltage between red and blue wires is 121.8 v this is correct, I think ...
I have also checked again the square waveform existing on the gate pins of the output FETS, and has improved greatly, looks more square.
Well, a more repaired amplifier, a million thanks for the help, Perry.
- General Interest
- Car Audio
- rockford fosgate t40001bd
