Rockford fosgate P8002 goes into protect - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 12th October 2016, 07:20 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default Rockford fosgate P8002 goes into protect
I'm starting a new thread for this one. So far I replaced output transistors with new ones all matching. Even replaced source resistors. I get audio clear audio but as soon as it's turned up past a certain volume it'll go into protect. I'm not sure what R1105, R1098, 1090 are I dint replace those. Any ideas what's causing it to go into protect? Thanks!
Feel the PUNCH
Old 12th October 2016, 07:22 PM   #2
Board number
Feel the PUNCH
Old 14th October 2016, 09:32 AM   #3
When you start a new thread for an amp that you had a previous thread for, post a link to the old thread.
Those resistors and R1079 drive over-current signal back to the over-current protection circuit.
Does it go into protect with either channel when you only drive one channel at a time?
Old 14th October 2016, 05:20 PM   #4
Gotcha! Only the left channel puts amp into protect when volume is turned up half way the other channel doesn't. What I noticed even with no load connected amp will still go into protect. I replaced the outputs in the left channel as well as the source resistors since they were out of tolerance. It plays music on hp and ap and bass signal isn't distorted either.
Feel the PUNCH
Old 14th October 2016, 06:21 PM   #5
Lift or remove D1002 and D1004. Does that change the way it goes into protect?
Old 23rd October 2016, 04:34 PM   #6
Removed D1002 & D1004 amp still kicks into protect at half volume.
Feel the PUNCH
Rockford fosgate punch p8002 channel repair chipper Car Audio 2 15th July 2016 09:19 PM
Rockford Fosgate bd1500 In protect RJohns777 Car Audio 32 20th June 2016 08:07 PM
Rockford Fosgate T3002 Protect mode jtaborsky Solid State 2 6th March 2016 12:31 AM
Rockford fosgate power t10001bd in protect chipper Car Audio 8 19th June 2015 07:32 AM
Rockford Fosgate BD15001 stuck in protect seankane Car Audio 34 1st April 2011 08:11 PM
Copyright 1999-2017 diyAudio
