car smps based on TL494
Old 10th July 2007, 09:47 PM   #51
CHACALPOWERS is offline CHACALPOWERS  Bahrain
CHACALPOWERS's Avatar
Hi Hugo
Iīm new here. I have various projects. Itīs builded from old equipments from trash. I donīt have money to buy new components. The projects are simple and no need discussion around it.
Thank you very much
Old 10th July 2007, 09:51 PM   #52
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
That's the spirit.
Also, keep in mind many here LOVE good discussions.
/Hugo
Old 10th July 2007, 09:58 PM   #53
Mr. Hugo
Thanks by your comments.
Old 4th January 2013, 09:44 PM   #54
AudioEngineer is offline AudioEngineer
Default Toroid Data for Car SMPS
Originally Posted by himanshuraval View Post
any body have full design of TL494 based car smps with toroid data
Hi Himanshuruval. Personally I would recommend you use the ETD39 with Ferroxcube 3C90 core halves or similar material. This is suitable for building car amplifiers which deliver around 350W RMS total continuous power. If you need more power than this you can try the next bigger core which is the ETD44 core with the suitable 3c90 core halves. The power you can get out of any particular core is dependent on frequency. Running the cores at around 100KHz is not a bad start.
About 4 turns on the primary will be sufficient for most cases. The number of secondary turns will of course depend on the output voltage(s) which you require.
If you must use a toroid then you can use something like the Ferroxcube TX42/26/13-3C90 or something similar.
Old 5th January 2013, 03:45 AM   #55
N-Channel is offline N-Channel  United States
N-Channel's Avatar
Send a message via AIM to N-Channel
Default Suitable Transformer Cores
A couple more choices to consider if you want to use a toroid are either the Amidon FT-140-77, or FT-240-77. The '140 has about 350W throughput capacity @ 100kHz, and the '240 can throughput about 1.7kW @ same freq. Both are made of #77 Ferrite material, which is great for SMPSs. The FT-140-77 is 1.40" O.D. and the FT-240-77 is 2.40" O.D. Primary turns for either core should be about the same: 4 + 4, but you will want to verify this through a good design regimen.
Hope this helps,
Steve
Last edited by N-Channel; 5th January 2013 at 03:47 AM. Reason: Typos & grammar errors
car smps based on TL494Hide this!Advertise here!
Making car amplifier SMPS with tl494 + DC Protection Risto80 Car Audio 775 22nd August 2017 10:34 AM
Reducing voltage of TL494 based supply? theAnonymous1 Power Supplies 27 31st July 2007 06:34 PM
SMPS noises with TL494 Todor Power Supplies 20 16th July 2005 12:56 AM
