Did you recheck the solder connections and look for solder bridges on Q7?
P Perry Babin Member Joined 2003 bcae1.com 2016-07-11 6:48 pm #21 2016-07-11 6:48 pm #21 Did you recheck the solder connections and look for solder bridges on Q7? ••• More options Share L luigidedom Member Joined 2011 2016-07-13 10:09 am #22 2016-07-13 10:09 am #22 Yes i have ill be going through all the vias as well maybe some corrosion damage ••• More options Share L luigidedom Member Joined 2011 2016-07-14 8:44 pm #23 2016-07-14 8:44 pm #23 Looks like a dud board, cant seem to track down whats causing the fault ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-07-14 9:24 pm #24 2016-07-14 9:24 pm #24 I would suggest that you stop removing the boards by breaking the terminals. Chipquik isn't cheap but it saves you from having all sorts of strange problems and prevents damaging the boards/vias. ••• More options Share Prev 1 2 First Prev 2 of 2 Go to page Go Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link
