Sundown SCV2000 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd July 2016, 02:20 AM   #1
Shane73 is offline Shane73  United States
Default Sundown SCV2000
I just picked up a Sundown scv2000d. The previous owner hooked it up to a single battery so that he could .test" the amp. He allowed the voltage to drop to far and burned up the power fets in it. They are UTC 70n06l. I am having trouble locating anyone who sells them. Is there a suitable equivalent to them? Thanks.
Old 2nd July 2016, 05:05 AM   #2
Did you find a datasheet for that part? The L suffix may be important.
Old 2nd July 2016, 05:27 AM   #3
Here is what I could find. I can only find the part number under the utc brand. I don't know if it is exclusive to them or not.
Old 2nd July 2016, 06:00 AM   #4
Sometimes the L in an FET part number means that it's logic level and has a logic level drive circuit (that won't work with standard FETs).
Look at the drive signal with your scope. If the amplitude of the drive signal is about 10v, it's a normal drive circuit.
The IRF3205 is sort of an all around replacement. If the drive circuit produces at least 10v of drive and uses an emitter follower pair between the driver IC and the FET, and the gate resistors are 47 ohms or less, the 3205s should be good subs.
Sundown sax125.4 mbates14 Car Audio 3 4th April 2014 05:01 PM
Sundown 3000 KTMrida4life Car Audio 25 16th November 2013 08:14 AM
sundown 1500dv1 ampjunkielikeme Car Audio 2 4th July 2012 10:59 PM
Sundown prototype mike49504 Car Audio 7 3rd January 2012 01:17 AM
Sundown SAZ3000 mike49504 Car Audio 50 20th December 2010 05:41 AM
Copyright 1999-2017 diyAudio
