Kicker ZX2500.1 Transistor Number
Hi all, does anyone know the number of Q101 on the main board. The sub in, off of the input board, is fed to this transistor through a resistor and cap. The transistor is shorting the signal to ground. The number on the transistor is BA21. I tried searching specks for this on line. Any help would be appreciated. Thanks.
Is this an smt? If you a post pic of the board and a close up of Q101 and surrounding circuit I may be able to identify part. I will check schematics.
Also,check the DC voltages on all the pins on input board, black probe on one of the transformer center tap leads.
Sent from my HTC Desire 626 using Tapatalk
The J108/109 appear shorted when there is no bias voltage on their gate.
Fairchild often puts the part number below the production code.
