MTX Thunder 1000D
MTX Thunder 1000D
Old 2nd April 2016, 02:15 AM   #1
S Merlington is offline S Merlington  United States
Default MTX Thunder 1000D
Anyone have pics of the board or can tell me the part number for this amp?
This is what i found when i pulled the bottom covers
Old 2nd April 2016, 02:28 AM   #2
Perry Babin is offline Perry Babin  United States
The output transistors (SSP45N20A) are discontinued and I've never found any subs that would work without modifying the amp's drive circuit. Someone may have found a good sub.
Old 2nd April 2016, 02:37 AM   #3
Theres only 2 outputs in this amp correct ? I may have 2 new ones laying around ..
And for the power supply fets would you recomend IRF3205'S or the 75339 ?
Rectifiers are 1540 ?
Old 2nd April 2016, 02:39 AM   #4
ian33 is offline ian33
I got outputs from UTSource and they work ok.
Old 2nd April 2016, 02:42 AM   #5
eight outputs
Old 2nd April 2016, 03:17 AM   #6
That's right 8 outputs don't know where I got 2 from ..
Old 3rd April 2016, 07:12 AM   #7
ian33:
We the outputs the SSP45N20A?
Did you use them in a 1000D or was it a similar model?
Old 4th April 2016, 02:36 AM   #8
Check the notes and it was a 8100d,using the 42N20D.
The pic had me,board look just like this one.
Old 4th April 2016, 09:43 AM   #9
There were 3 models that were very similar (81000d, 1000d and 1501d). The amps with individual gate resistors for each output used the IRFB42N20D. The others used the SSP45N20A. The amps without the individual gate resistors wouldn't work with the IRFB42N20D (from my experience).
Are you sure that your amp was an 8100d instead of an 81000d?
Old 4th April 2016, 11:33 AM   #10
I am not sure if i had the number right but this is the thread i started for that amp.I still have two of outputs form what i bought from them.
mtx 81000d
MTX Thunder 1000DHide this!Advertise here!
MTX 1000D Amp Exbass17 Car Audio 3 24th November 2014 05:23 AM
Thunder 1000D mbates14 Car Audio 7 16th October 2014 05:08 PM
MTX 1000D Problem Exbass17 Car Audio 43 13th October 2014 05:25 AM
MTX Thunder 801D S Merlington Car Audio 32 12th November 2013 04:25 PM
Help me fix my MTX 1000D, no sound, just static hakentt Car Audio 13 30th October 2009 04:33 AM
