yes
P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 7:13 pm #21 2016-01-31 7:13 pm #21 yes ••• More options Share Y yoppi Member Joined 2016 2016-01-31 7:14 pm #22 2016-01-31 7:14 pm #22 1,2v and -1,2v ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 7:15 pm #23 2016-01-31 7:15 pm #23 Do you have an oscilloscope? ••• More options Share Y yoppi Member Joined 2016 2016-01-31 7:16 pm #24 2016-01-31 7:16 pm #24 Yes ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 7:21 pm #25 2016-01-31 7:21 pm #25 With nothing connected to the amp, what is the resistance between the shields of the two sets of RCA jacks? ••• More options Share Y yoppi Member Joined 2016 2016-01-31 7:28 pm #26 2016-01-31 7:28 pm #26 RCA connector infinite resistance between red and white RCA connector ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 7:30 pm #27 2016-01-31 7:30 pm #27 Are D198, D199 and the large resistor between them in the circuit? ••• More options Share Y yoppi Member Joined 2016 2016-01-31 7:44 pm #28 2016-01-31 7:44 pm #28 if they are. I have checked and are correct. ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 8:12 pm #29 2016-01-31 8:12 pm #29 Measure the resistance between the point shown. Attachments P4200026x.jpg 82 KB · Views: 101 ••• More options Share Y yoppi Member Joined 2016 2016-01-31 8:14 pm #30 2016-01-31 8:14 pm #30 Continutity ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 8:18 pm #31 2016-01-31 8:18 pm #31 Any resistance less than infinity can be considered continuity. Do you mean that you read 0 ohms? ••• More options Share Y yoppi Member Joined 2016 2016-01-31 8:26 pm #32 2016-01-31 8:26 pm #32 ok now I understand. the resistance is 1,5ohm ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 8:30 pm #33 2016-01-31 8:30 pm #33 If I understood correctly, you stated that you replaced the two 0.22 ohm resistors for the low voltage supply. Is that correct? ••• More options Share Y yoppi Member Joined 2016 2016-01-31 8:45 pm #34 2016-01-31 8:45 pm #34 if 2 SMD resistors are replaced. ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 8:50 pm #35 2016-01-31 8:50 pm #35 Did you re-check them after applying power to see if they opened again? ••• More options Share Y yoppi Member Joined 2016 2016-01-31 9:01 pm #36 2016-01-31 9:01 pm #36 if, now have their correct value ... ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 9:09 pm #37 2016-01-31 9:09 pm #37 There is a language barrier. Please take the time to more clearly answer the questions. ••• More options Share Y yoppi Member Joined 2016 2016-01-31 9:13 pm #38 2016-01-31 9:13 pm #38 Sorry, resistors 0,22ohm work well ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2016-01-31 9:18 pm #39 2016-01-31 9:18 pm #39 What signal do you see on the center leg of Q471 (with your scope)? It should be a square wave. ••• More options Share Y yoppi Member Joined 2016 2016-02-01 10:17 am #40 2016-02-01 10:17 am #40 Good morning from Spain Do you refer to FET 471? Regards. ••• More options Share Prev 1 2 3 4 Next First Prev 2 of 4 Go to page Go Next Last Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio MTX 1501D problem power supply Top Bottom
