R29c is burnt ,does that mean the 4080 is gone to? It has no shorted outed outputs,
H Hexhclass Member Joined 2010 2015-12-15 1:27 am #1 2015-12-15 1:27 am #1 R29c is burnt ,does that mean the 4080 is gone to? It has no shorted outed outputs, ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2015-12-15 1:37 am #2 2015-12-15 1:37 am #2 They always look a bit dark. If it's burned out of tolerance, check ZD1C. ••• More options Share Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button.
