Rockford Fosgate 600.4 Gain pod - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 6th December 2015, 07:26 AM   #1
Question Rockford Fosgate 600.4 Gain pod
Does anyone know what the value of the gain pod for the fosgate 600.4?The board placement is RV300-A & RV300-B. Both of the gain potentiometers are bad horrible static when adjusting. I think the value is 5K but I want to make sure. The schematic does not show a value either. Any Help would be appreciated. Here is a picture.
Old 6th December 2015, 11:28 AM   #2
Have you tried contact cleaner?
What are the numbers on the side of the pot?
Old 6th December 2015, 05:54 PM   #3
They are way to much play in them to be fix with contact cleaner
I fixed the missing picture the number's on the side of the pod is (385K Ohms X2)
Old 6th December 2015, 06:39 PM   #4
3B is the resistance taper. 5k is the value of each pot. There are two pots.
Rockford used to sell parts. I don't know if they still do. If not, Mouser probably has something that will work.
I've had to replace less than 5 of these pots in the many hundreds of amps that I've repaired that used these pots. All others cleaned up with contact cleaner.
Old 6th December 2015, 07:12 PM   #5
Thanks Perry. I was looking at mouser site last night this is what I found
Click Link> PTD902 Bourns 5 kOhms Potentiometers | Mouser
Rockford Fosgate Prime 600.4D Groundcontrol Car Audio 3 16th June 2015 06:59 PM
old Rockford fosgate 600.A4 tiomilo Car Audio 6 6th September 2014 03:37 PM
Rockford Fosgate 600.5 mike49504 Car Audio 70 22nd June 2012 10:38 PM
ROCKFORD FOSGATE 600 A4 mike49504 Car Audio 5 20th January 2012 12:28 PM
Copyright 1999-2017 diyAudio
