Can someone please identify resistor R443 on this amp or if someone can send me the schematic diagram.
I've add the picture of the area.
All 4 channels are the same, the resistors are beyond recognition on identifying the colors. I'm wondering if it's a 4.7 ohms but just want to be sure.
From what (little) I know about PG amps, they typically use a 4.7 ohm resistor across the inductor and amps that have the output inductor, they use a 4.7 ohm in series with a small capacitor across the output of the amp. In amps that don't use the output inductor, a higher value (22 ohm?) resistor is used (in series with a small capacitor) across the speaker output. If you can't get any definitive answers, maybe this will help you find suitable replacements.
- General Interest
- Car Audio
- Phoenix Gold XS4600 resistor burnt
