Percision Power DCX 1500.1
Old 17th September 2015, 12:26 AM   #1
S Merlington is offline S Merlington  United States
Default Percision Power DCX 1500.1
Anyone know the value of these resistors?
I believe they are for the RCA shield ground
Old 17th September 2015, 12:42 AM   #2
Perry Babin is offline Perry Babin  United States
Old 17th September 2015, 12:51 AM   #3
Are these 1/4 watt?
Or are they 1 watt do you know by chance?
Reason i ask is because ive orderd resistor from Digikey before and the 1 watt resistors are in a 1/4 size
Old 17th September 2015, 08:01 AM   #4
A resistor's size is determined by the heat that the components that it's made of can withstand. Smaller resistors with high power ratings are made of components that can operate at higher temperatures than common resistors. When I order resistors rated for more than 1/4w from DK, I generally order the light-blue Panasonic resistors.
I don't know what the rating on the original resistors is. They are connected between the RCA shield and the secondary ground. There is essentially no current through them during normal operation.
Percision Power DCX 1500.1Hide this!Advertise here!
Do You Have an old Blown Percision Power PPI 12 inch flat piston? newtothis Car Audio 1 11th June 2015 06:15 AM
power 1500 bd timwebb Car Audio 11 5th December 2013 12:44 AM
DCX 2496 power supply IMSTOOPID Digital Line Level 6 29th January 2013 05:24 AM
Linear Power Supply for DCX or DEQ 2496 kepa1 Swap Meet 5 8th January 2012 06:11 PM
Precision Power DCX 1000.4 Opinions? Rweasel6 Car Audio 0 11th May 2005 05:46 PM
