Earthquake Powerhouse D2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 4th September 2015, 09:34 AM   #1
Default Earthquake Powerhouse D2
Have one here that blew most of the RFP40N10's. Blew 10 amp fuse when I applied power. Cut the legs to all the output fets and now amp light comes on.
What should I check from here?
Old 4th September 2015, 04:10 PM   #2
JonSnell Electronic's Avatar
Find and repair the fault then replace the FETs, drivers. and associated damaged components.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 4th September 2015, 10:52 PM   #3
I'd suggest the IRF3710Z (Z is critical). HIP4080 will likely need to be replaced as well.
Old 5th September 2015, 03:29 AM   #4
Thanks for the fet advice. I already have the new HIP4080. What should I see at each of its pins?
Old 5th September 2015, 09:41 AM   #5
You cannot check the signals on the IC without the FETs in the circuit unless you short various terminals in the circuit. I don't have a diagram for this amp so I can't tell you which pins to short.
Old 5th September 2015, 02:40 PM   #6
Hi Perry,
Does the hip4080 drive the outputs? You recommend a IRF3710Z for output fets will the FQP85N06 be okay on the input side? Do you have a favored substitution for it as well. I think this amp was a modded one. I read the other write up and think I had the 1.5KE68A Zener anti feed back protection diodes at the fets but yet it was still installed on HIP4080 chip legs. It also reads that replacing R08 with a 10ohm and R37 with a 75K will increase the rail voltage.It also reads that changing the internal fuse from 20 to 30 amps will allow over-driving the amp at 1/2 an ohm for SPL applications.
Perry the article suggest needing to check the anti feed back diodes at the same time I check the gate resistors. The resistors should be 10 ohms @ 1%.
Can I begin by looking for driver signals at the TC4424?
Also this photo taken from the web shows a large ceramic resistor in between the speaker outputs and a bipolar 47Uf cap. Where can I find these items and any idea the wattage rating on the ceramic resistor?
Old 5th September 2015, 03:08 PM   #7
Can anyone confirm the colors on the ceramic resistor Im asking about?
Your time and patience is greatly appreciated.
Old 5th September 2015, 10:00 PM   #8
I will not help modify the amp.
The first color band on the resistor could be either red or brown. It's difficult to see but it's likely a 0.2 ohm. One photo I have shows a 0.47 ohm there. It's likely 2w. Order whatever resistor that matches the dimensions of the one in the amp.
I don't know what an anti-feedback diode is.
Old 6th September 2015, 12:04 AM   #9
The resistor is a 0.2 ohm 2 watt..
I have the same amp here on the bench
Old 6th September 2015, 02:14 AM   #10
Thank you Mr Merlington. Do you or anyone else have a source for the 100volt bipolar cap?
Thanks again.
Hugh
Earthquake PowerHouse D2 outputs DC and high pitched squealing noise Purpose Car Audio 8 28th April 2015 01:53 AM
mmats d200hc and earthquake d2 gate drive signal spooney Car Audio 1 24th June 2011 03:35 AM
Help needed on Earthquake d2 amc32 Car Audio 5 16th December 2009 12:49 AM
Xonar D2 anyone? mlihl Digital Source 0 26th April 2008 09:44 PM
DIY powerhouse amp pjpoes Solid State 26 30th September 2005 05:56 AM
Copyright 1999-2017 diyAudio
