That would mean that those 3 FETs have failed and likely the other 3 in that power supply.
Both power supplies commonly fail but if this amp has separate fuses for each supply, the other supply may have survived. It's also possible that the output transistors have failed (causing the supply to fail.
The resistors are likely 100 ohms. They will be the same as the ones connected to the gate legs of the rest of the power supply FETs.
- General Interest
- Car Audio
- Power Acoustik resistor question
