Ok, I just wanted to verify with you guys, that without doing the big 3 first,That it wouldn't throw off the test results. Thanks for correcting me on this. When my car gets back from the shop, I will have all the info I need to test and verify things. I would still like to have the information on if I was right or wrong about everything I discussed with the big 3. Thanks
You will learn a lot more that way.Measure first, fix second.
Yes, you may need to fix your grounding. But if you do some measurements 1st, then fix problems (if you find any) that will give you good knowledge. You'll learn how to diagnose the problems yourself and be able to chase down gremlins.
