fosgate MOSFET power 1000c help!!! - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 29th June 2015, 06:30 PM   #1
Default fosgate MOSFET power 1000c help!!!
OK I've looked at the manual can't figure out how to bridge amp down to one channel. Amp is set to 2 channels, I'm pushing 2 12w6v2 in a series. What color wires do I use to bridge the amp? Also looking for a fosgate MOSFET chrome 650.
Thanks for your help!
Old 29th June 2015, 09:03 PM   #2
diyAudio Member RIP
According to the (confusing) diagram its a 4 channel
amplifier that can be wired as 2 channel bridged.
It can't be reduced to one channel bridged.
It can be wired as 2 channel parallel for 1 channel with
some additional series resistors and an input splitter.
rgds, sreten.
Old 29th June 2015, 09:07 PM   #3
I think I'll just wire it parallel/ 2 channel. 1 channel each speaker. Its 4 amps in 1! The diagram is very hard to figure out. But it think I understand it.lol
Thanks.
Old 29th June 2015, 09:15 PM   #4
diyAudio Member RIP
2 channel wiring is bridged. L + R in.
Output is across Lfront/Lrear and Rfront/Rrear.
rgds, sreten.
Old 29th June 2015, 11:18 PM   #5
What's the impedance of each individual voice coil for the woofers?
Old 4th July 2015, 11:24 PM   #6
The woofers will handle it. Just need to bridge it down to one channel. Sreten you last post I didn't understand?
Thanks. Also looking for a fosgate MOSFET chrome 650.
Old 6th July 2015, 06:50 PM   #7
diyAudio Member RIP
Your not making sense.
You can't bridge it down to one channel.
Its 4 channel or 2 channel bridged.
For the 2 channel setting outputs are :
Left : White/Orange, Right : Gray/Brown.
rgds, sreten.
Old 7th July 2015, 05:10 PM   #8
Perry was not asking if the woofers can handle the power or not ..
The reason he asked what ohm is each voice is because if you run the amp below the recommended load you will burn the amp up ..
Old 8th July 2015, 05:00 AM   #9
JLs are Dual 4 ohm. The amp is 2 ohm or great. 2 channels bridge, is one channel. The amp has a push button 2or4 channel. It is set to 2 channel. I need to bridge it. Its OK now tho. I got it all taken care of. It is bridge and it is bumping. MB quart 6,4 tweet with 2way mb quart 5 1/4 n the back. Power 1000c pushing 2 12w6v2(3 12w6v1 on the way). JL black 300/4 push mids and tweets. Phoenix Gold TBA,215eq,blocks and fuse blocks all made in USA! Trunk is almost done!
Old 8th July 2015, 10:05 AM   #10
The only safe/practical way to use this amp (all 4 channels) with those speakers is one voice coil per channel. Bridging two channels to one 2 ohm woofer will cause the amp to fail if driven hard. Bridging 2 channels to one 8 ohm woofer is the same as one coil per channel.
Old school Rockford Fosgate Power 1000c MOSFET Prime mova Car Audio 31 6th June 2013 08:16 AM
Rockford Fosgate Power 1000C seankane Car Audio 19 15th March 2013 06:22 PM
Rockford Fosgate Power 300 Mosfet seankane Car Audio 21 2nd February 2013 09:49 PM
rockford fosgate power 300 mosfet mike49504 Car Audio 26 23rd December 2009 04:06 AM
Copyright 1999-2017 diyAudio
