diode D204 and D204a this is a 2 channel amp which had fried 1 of the channels, ive replaced the outputs and fitted a new driver card. the unrepaired channel is working fine, the repaired channel doesn't oscillate at all and i found D204a shorting, removed it and its marked B12.
i assume D204a is a 12v zener as D204 measures 12v across it but if i fit a 12v zener in place of D204a i get only 0.65v across it
- General Interest
- Car Audio
- Diode B12
