PPI pc21400 noise when power on after a repair
Old 9th March 2015, 03:16 AM   #1
dmuney is offline dmuney  United States
Exclamation PPI pc21400 noise when power on after a repair
Ok bought a PPI pc 21400 off eBay amp worked great then a few months later it started to have low and distorted output so I removed back cover and found 1 rectifier had a broken terminal and a resistor looked to be burnt by the power supply input it was a 260 ohm 3 watt so I replaced both components I also tested all transistors all test good so I reassemble amp. I powered up with a 100watt 2 ohm resistor in batt+ just to be safe and when I power amp on I makes a sound like your frying bacon . Amp draw with no input or output connected is only 1.75 amps , no school current on speaker outputs. I read Perry's artical about the two small boards and there issue according to Perry's tests they are ok. I'm concerned and frustrated with this repair any help would be deeply appreciated. The person I bought the amp from has been a great help and if I can't repair it I'll send it to him for repair I'm just trying to save $100+ and not have to ship it. Perry if you read this the fine gentlemen that I purchased this amp from said you were his teacher and when I was having problems in the beginning he told me go to Perry's site I said I've read your site 5 times from start to finish I just need to buy the full version. Thank you to anyone who could help me with this problem. And before you ask no I never powered up amp without back cover ok I did but only after I made some bars to clamp transistors down tightly thanks.
Old 9th March 2015, 07:22 AM   #2
Talking fixed
load limiting resistor was problem removed and amp works perfect
PPI pc21400 noise when power on after a repairHide this!Advertise here!
PPI Precision Power a1200.2 repair? iconmoto Solid State 2 27th April 2013 03:55 PM
PPI PC21400 mike49504 Car Audio 3 22nd August 2011 11:29 PM
PPI Amp Problem - PC21400 EVOlutionary Car Audio 5 5th February 2006 04:42 PM
ppi pc21400 resistors burned out focuspower1320 Car Audio 2 23rd August 2005 08:18 PM
PPI PC21400 line drivers renzo Chip Amps 0 16th February 2004 02:13 AM
Copyright ©1999-2017 diyAudio
