is there any problem replacing the original power supply 50n06 with 65n06? i have 6 out of 12 50n06's burned up but i dont have any here but i do have 65n06
1 more question. Is it normal for U4 on the output board to be fairly hot when running? Amp is up and working got clean sound just wondering about that
The op-amp nearest to the edge of the board operates at very high temps. The two transistors in the yellow rectangle should be replaced. They have a very high failure rate. They run much hotter than the op-amp.
I can't answer that question. I've never had one of these in the shop. Before I'd worry about the caps, I'd replace the two transistors. They could be causing problems.
