Two channes on this amp plays low and distorted.One of the output transistor is geting
hot when i connect a speaker to the channel even with no singal applied.
I had that same problem with a crunch amplifier and to get the amp wprking.I had to
decreasing the value of the resistor connecting between the base and collector of the bias transistor.
I also tried bridging the emmiter and collector of the bias transistor but no change. Any ideas?
output transistor
1:0.788
2:23.07
3:0.390
bias transistor
1:0.974
2:1.079
3:1.019
output transistor
1:0.788
2:23.07
3:0.390
bias transistor
1:0.974
2:1.079
3:1.019
