hifonics protect issue - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 24th December 2014, 04:49 AM   #1
prls is offline prls  United States
Default hifonics protect issue
working on hifonics bxi2010d that was stuck in protect mode. I check the output transistors and there good. I remove the driver board and it came out of protect. I then removed and replace the MMbta42 transistor that are the ones that go bad and used mmbt3904 marked 1a instead of 1d. when the car is off 12.4 volts it works perfect but as soon as I turn the car on it goes into protect. I remove rca and speaker wires just power going to it and if car is on it goes straight to protect , if I turn the car off the amp works fine. could me replacing the mmbta42 with mmbt3904 be the issue here.
Old 24th December 2014, 11:54 AM   #2
Class D you should used the originals.
Old 24th December 2014, 02:54 PM   #3
The voltage is likely causing the 3904 to break down. When the engine is running, the breakdown is more likely if the rail voltage in the amp is unregulated.
Hifonics BXI608 in protect mode keelytn Class D 0 14th July 2014 11:26 PM
Hifonics 2010D Protect Mode Help. bl4ckw1d0w Car Audio 6 7th October 2013 04:10 PM
Zx6400 hifonics strange protect mode rafcio363 Car Audio 13 28th August 2013 09:56 PM
Hifonics HFI2000D goes to protect brandes.cm Car Audio 18 20th June 2012 06:29 PM
Hifonics Zeus VIII stuck in protect mbates14 Car Audio 11 16th May 2012 02:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
