Need help with Clarion apx 320.2 repair - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 21st December 2014, 05:20 PM   #1
grandic is offline grandic  Canada
Default Need help with Clarion apx 320.2 repair
Amp was dead, found 6800uf power supply cap and all output transistors deffective, replaced all and one channel is working perfectly, the other is distorded and 22 ohm resistor from the photo overheats when I increase volume. If it works on high volume/power it starts smoking and burns out in matter of seconds.
I'm not sure if it's a tip 31/32/35/36 not beeing properly paired because I don't have any left to try or it's something else that causes distortion and 22ohm resistor overheating.
If someone could help me with this that would be great and appreciated .
Old 21st December 2014, 06:37 PM   #2
If that resistor is burning, it's likely that the TIP35 is open base to emitter.
Old 21st December 2014, 09:36 PM   #3
I will check that... thanks for hint.
Just wondering, if TIP35C was open base to emiter, would it be possible for that channel to work, because it does... with full power but very noticeable distortion and 22ohm res overheating ...
Thanks again.
Old 21st December 2014, 09:41 PM   #4
I would expect the top half of the waveform to be badly clipped at higher power.
Old 21st December 2014, 09:47 PM   #5
It's distorted even at low power. So does it mean that amp can produce sound with tip35 BE open ?
Old 21st December 2014, 09:54 PM   #6
Yes.
Old 21st December 2014, 09:55 PM   #7
Yes.
Thanks Perry.
Old 24th December 2014, 11:05 PM   #8
Perry. I checked what you suggested and you were right. Base leg on 35c was broken, almost invisible for the eye but broken. Soldered it and works like a charm.
Thanks very much for your help.
Problem with a Clarion APX 401.4 ! NO SOUND stuparumihairadu Car Audio 5 21st December 2014 09:44 PM
Problem with a Clarion APX 401.4 ! NO SOUND stuparumihairadu Car Audio 1 28th October 2014 09:44 PM
Clarion DPX11500 #2 Repair Zeptoplix Car Audio 103 27th March 2013 01:48 AM
Clarion Dpx11500 repair help Zeptoplix Car Audio 19 15th February 2013 06:58 PM
Clarion DPX11500 Repair Help Zeptoplix Solid State 0 21st January 2013 08:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
