JL Audio 1000/1 Diode replacement - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 12th December 2014, 04:18 AM   #1
jlind54 is offline jlind54  United States
Default JL Audio 1000/1 Diode replacement
I'm looking to replace an SF1606GA which is a common anode diode in a T0-220AB package. I'm not having much luck finding any thing suitable that is in stock. After contacting Thinki Semiconductor in China and finding out they want to charge $50 to ship a .41cent piece I was hoping maybe someone here might know of a suitable replacement that can be picked up a bit cheaper.
Old 12th December 2014, 08:14 AM   #2
please back thread...you can use other diode replacement with correct or higher current rating and voltage. They are super fast diode.
Old 12th December 2014, 01:30 PM   #3
I've searched though as many threads as I could find that were related to diodes, I've not found any that mention common anode diode replacements, if it were a common cathode diode there are plenty of them to choose from.
Old 12th December 2014, 06:43 PM   #4
evianamp2011's Avatar
Alibaba seems to have a few suppliers....all from china though.
Tek 465, Fluke 111, TPI 440, AudioAuthority 2/77 Power Supply, Alpine HU for signal or Eico 379 Sine/Square Wave Generator.
Old 12th December 2014, 06:51 PM   #5
china seems to be only source other then mouser Europe
this might work:
http://www.ebay.com/itm/New-BYV32E-2...item3a9bdcbcc6
This part is 200 volt rated so unless you got some huge rail voltage in that amp I don't know about this will probably work fine
Old 12th December 2014, 06:59 PM   #6
90scaraudio's Avatar
$0.98 ea from mouser...
SF1606G Taiwan Semiconductor | Mouser
Old 12th December 2014, 07:16 PM   #7
Originally Posted by 90scaraudio View Post
It has to be GA on the end of the part number so its common anode.
Old 12th December 2014, 07:22 PM   #8
HI Cec.... been a while...
Well crap! Can it be lower than reverse Voltage of 400v?
Like this...
http://www.mouser.com/ds/2/308/MUR1620CTR-D-79742.pdf
Old 12th December 2014, 07:26 PM   #9
I was trying to avoid sourcing from China due to shipment time and cost, to get it in a 15-21 day span is around 50$ shipping according to two places there that produce parts. I'm not sure the 200volt part would last long with 300+ voltage spikes according to the oscope
Old 12th December 2014, 11:20 PM   #10
I don't understand why they would charge more than 4 bucks...I've purchased small goofy props from Ebay (China) for 2.00 postage INCLUDED. Takes about 15-18 days so it's not that bad.
Replacement diode for JL-HD 750 nonprof Car Audio 3 14th August 2014 04:00 AM
JL Audio 1000/1 S Merlington Car Audio 110 15th December 2013 09:02 PM
Jl audio 1000/1 megael9 Car Audio 4 20th June 2013 10:23 PM
JL Audio 1000/1 S Merlington Car Audio 34 1st December 2012 05:32 PM
JL Audio 1000/1 Dr Zeus Car Audio 33 8th February 2012 03:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
