I just now looked at your post with scope capture. The triangle seems a bit unstabe,and could be the result of poor scope ground. Make sure the scope is well connected to the negative speaker terminal.If this doesn't clear up the waveform,we will worry about it later, it may be just a minor issue,which I will address at a later time.
