mtx xd 600 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 13th October 2014, 04:40 PM   #1
prls is offline prls  United States
Angry mtx xd 600
im having a bit of trouble with amp. it works fine but the inductor gets hot fairly quick with no load on it. i remove the caps and check them and the are good, dont know what else could cause problem.
Old 14th October 2014, 01:16 PM   #2
The inductors in most MTX amps run 'hot' but you have to realize that what's hot to the touch isn't necessarily hot for an inductor. The components that make up the inductor can stand high temperatures (200F+). If the inductor isn't melting the solder on its terminals and the inductor heats up uniformly around its perimeter, it may be OK.
If the amp has a fan and the fan forces air across the inductor and the fan only runs at full speed at high power/temperatures, the inductor may operate at lower temperatures when the amp is under normal operation.
Old 14th October 2014, 04:25 PM   #3
Default mtx xd 600
there is no fan on this amp just the inductor. when i remove the output mosfet
it doesnt get hot. plus i measure 42.3 khz on the output mosfets. is that normal?
Old 14th October 2014, 07:16 PM   #4
I don't know what the output stage oscillates at in this amp and have no information on the amp (not even photos). 42K seems low but may be OK for this amp.
With the output transistors out of this amp, there is nothing being driven into the inductor.
600:600 ohm output transformers for v-out DAC - $40 for 2 wireswithgain Swap Meet 11 5th November 2013 10:53 AM
FS: NEW Jensen JT-11-YMPC Output Transformer 600:600 Perfect for any v-out DAC! wireswithgain Swap Meet 9 18th October 2013 04:29 PM
FS: LM49710/LM49600 Amp (The Wire-ish) and +-15v Bipolar supply, 600:600 Transformers wireswithgain Swap Meet 13 14th August 2013 02:54 PM
FS cinemag transformers nickel CMOQ-2H 600:600 Gluca Swap Meet 10 6th March 2013 06:01 PM
Tango NN-600-600 input transformer syklab Parts 3 5th September 2012 05:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
