Noob Question? - Different load ratings for same amp? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 12th October 2014, 03:17 AM   #1
Default Noob Question? - Different load ratings for same amp?
Ok, this may be a stupid question, but I've always wondered why MMATS and some other companies have the same "model" amp, but rated at different ohm load capabilitys. So for example they have a 2000.05 (1/2 ohm stable), 2000.1 (1-ohm) and 2000.2 (2-ohm)
What are they changing in the amplifier to get the different load capability?? Wouldnt it have to be a TOTALLY different amp? If the load rating goes down, then wouldnt the power go up? So do they reduce the voltage produced by the power supply to maintain the same power? If so, why would'nt they just leave it the same an call it a 3000 watt, or 4000 watt etc amp??
Wouldnt a 4000.05 technically be the same thing as say a 2000.1??
Sorry if Im being totally confusing. lol
It appears they use the same board for all of a given model (IE 2000.05, 2000.1, 2000.2) because the board just says "D2000". Without specifying a load rating. So what is the deal here. What are they changing inside?
Again, this is probably a REALLY stupid question, its just weird to me that they do things this way.
Old 12th October 2014, 03:39 AM   #2
Vasquo is offline Vasquo  United States
Given an amplifier circuit, it will dissipate more power as the Rload decreases. i.e. 2 ohm will have double the power than 4 ohm, 4ohm double the power than 8 ohm, 8 ohm double the power than 16 ohm.
But if Rload is lowered, the transistors/mosfets in the amplifier's output section may exceed it's SOA (Safe Operating Area) i.e. more power dissipated/more heat/more current which may exceed the transistor's/mosfets power rating.
So to allow more power dissipation, and lower Rload, what manufacturers do is usually parallel several transistors/mosfets in the output section. That way, power dissipation is distributed and shared among several output sections, ensuring each section is still within it's safe operating area.
So the amplifiers may share the same front end and driver circuitry, and the only difference is more paralleled output section on the higher wattage models. For example: Crown amplifiers model XLS 202, 402, 602, etc... it's the same circuitry. Only difference is the 402 and 602 models have more output stages in parallel.
Old 12th October 2014, 04:00 AM   #3
Like I said though, it appears they use the same number of outputs and same board in all models of the same wattage rating.
Here is a picture of the guts from a D2000.05
And although I have all the FETs out, here is my D2000.2 You can see they are essentially the same, same number of PS FETs, same number of output FETs.
So what the heck is going on here?
Old 12th October 2014, 04:03 AM   #4
Only obvious differences I see is possibly different torroids. They have stickers with ratings on them so I assume they have a bunch of different ones for a reason.
And also the .05 has an extra current sense resistor that my .2 does not. Mine has the spot for it, but nothing there.
Old 12th October 2014, 10:59 AM   #5
Changing the rail voltage from amp to amp is generally how they change the lowest rated load impedance if the amps are otherwise identical.
The extra shunt resistor is to reduce the sensitivity of the over-current protection.
Old 12th October 2014, 02:25 PM   #6
Wouldn't that change the wattage as well though?
Old 12th October 2014, 02:31 PM   #7
Or does the lower impedence load counteract that? So if you lower the rail voltage you can allow for a lower load correct? So the lower load brings the wattage back up correct?
Old 12th October 2014, 06:06 PM   #8
Lower rail voltage REQUIRES lower load impedance to produce the same power. The lower rail voltage also reduces (to a safe level) the current flow through the output transistors when driving the low impedance loads.
Old 12th October 2014, 06:20 PM   #9
At it's simplest, P = V^2/R ; where R is 2,4, or 8 ohm, and V is output voltage
Lower the R, you increase power and vice versa.
Increase V, you increase power and vice versa.
The caveat is the increase in power dissipated doesn't exceed the power rating of the output stage, or go outside the safe operating area.
Old 13th October 2014, 12:10 AM   #10
So is there a way to lower the rail voltage to allow for lower loads? Without changing the torroids? Can't I lower the PWM frequency somehow? Wouldn't that do it?
is current in speaker load to be anyway closer to psu current ratings? rhythmsandy Solid State 50 10th December 2012 09:50 AM
noob question about sure's 2x100W amp helemaalnicks Class D 5 1st September 2011 02:32 PM
Output dissapation ratings vs amp ratings jol50 Car Audio 3 16th April 2010 11:49 PM
Question about Allied & Hammond Power Transformer Ratings Bitrex Tubes / Valves 2 6th March 2009 07:31 AM
Noob question about plate load eforer Tubes / Valves 14 23rd May 2006 05:24 AM
Copyright 1999-2017 diyAudio
