mx 3040
mx 3040
Old 25th September 2014, 12:06 AM   #1
ian33 is offline ian33
Default mx 3040
This Sony amp protect and power LED is on.When i power the amp the relay engage and disengage very quickly.Amp has rail voltage .I get good audio on the relay.I think the protection circuit has a fault.Any idea what to check?
Old 25th September 2014, 12:22 AM   #2
Perry Babin is offline Perry Babin  United States
XM-3040F?
Old 25th September 2014, 12:26 AM   #3
I thinks so,amp is old so maybe the F fade out.
Old 25th September 2014, 12:33 AM   #4
I just saw a pic of the F version and mine is different.The relays are mounted on a small board soldered to the main board. I will post pic tomorrow but mine look just like this but with black relays.
Not my pic""
http://i598.photobucket.com/albums/t...0/DSC02473.jpg
Old 25th September 2014, 02:17 AM   #5
Post the DC voltage on all pins of IC505.
Old 25th September 2014, 11:49 PM   #6
IC505
1: 0.948
2: 0.275
3: 0.651
4: 1.879
5: -0.104
6: 11.60
7: -0.056
8: 3.148
The voltage was stable only for pin 6 and 8. The rest was going a little up and down.
Base on the date sheet for that IC pin 8 Vcc should be higher than that.I pull the IC and
got 15.65v on the Pad pin 8.I put the IC back in and soldered pin 8 and 5 .I check voltage again
and it went back to 3.148.
Old 26th September 2014, 05:40 AM   #7
The voltage on pin 8 is probably OK. Pin 1 is above the threshold for that input. That's the over-current detect input. Pulling Q505 should defeat that part of the protection circuit and allow you to determine if there is a true over-current fault or a fault in the protection circuit. The Qx06 transistors are the over-current detection transistors for the individual channels.
Old 27th September 2014, 12:43 AM   #8
I pull each over-current transistor one by one but no change.I pull Q505 amp is out of protect ,but after about 1 min comes back in protect.when amp was out of protect i get good audio on all channel.
Q505 in circuit
E: 22.56
C: 22.62
B: 21.98
out if circuit pads read
E: 25.60
C: 3.04
B: 23.92
With Q505 out i get 1.096 on pin 1 of IC505.With all parts in circuit if i GND pin six or seven amp comes out of protect
Old 27th September 2014, 01:08 AM   #9
If IC505 has voltage on pin 1, the problem may be the thermistor or the connections to the thermistor. Try grounding pin 1 of IC505 to see if that prevents it from going into protect mode but be careful in case there is a real fault.
Grounding pin 7 shouldn't (as far as I can tell) prevent the amp from going into protect mode.
Grounding pin 6 simply switches on the relay drive transistor which engages the relays.
email me if you want the diagram.
babin_perry@yahoo.com
Old 27th September 2014, 01:52 AM   #10
When i ground the pins i hear the relay engage so i assume it was out of protect in that state.
I will check the thermistor tomorrow.
mx 3040Hide this!Advertise here!
Hi, new in this land from Mx julio c Introductions 4 16th November 2012 07:43 PM
MX sub question carshateme Subwoofers 2 30th September 2011 11:22 PM
Ads Mx 860 capea4 Car Audio 1 2nd April 2008 02:02 AM
Yamaha MX-70 bekim Solid State 5 23rd April 2007 06:38 AM
Gale 3040 Loudspeaker eranrund Multi-Way 0 19th June 2003 07:53 AM
