Sub woofer  help
Sub woofer  help
Old 8th September 2014, 07:34 AM   #1
wdc112210 is offline wdc112210
Default Sub woofer help
I am thinking about picking this sub up for $40 what do you guys think give me your options
Old 8th September 2014, 10:42 AM   #2
90scaraudio is offline 90scaraudio  United States
90scaraudio's Avatar
$40.00, not bad. As long as it's tuned correctly and sounds good to you. You could hardly build the box for that. If you don't like it, you could always sell it.
Good luck.
Old 8th September 2014, 10:52 AM   #3
I am kinda a noob but how to you (tune) it ?
Old 8th September 2014, 01:07 PM   #4
It should be tuned for the sub already. They are usually sold this way. Size of box and port tubes cut to length is how it's tuned.
Old 8th September 2014, 11:48 PM   #5
Is there a site that I can use as a guide just in case it is not tuned correctly or if I change the sub
Old 9th September 2014, 12:10 AM   #6
The Subwoofer DIY Page - 4th Order Bandpass Systems
Lots more info on the Web if you search for it.
Old 9th September 2014, 01:15 AM   #7
Perry Babin is offline Perry Babin  United States
To determine if it's properly tuned requires that you define what you want. Many of these pre-fab 4th order enclosures are designed to produce significant output in a very narrow band. This can make them impressive in that narrow band but can also make for a 'one-note' system.
After you decide what you want, you have to know what your vehicle's transfer function is and then tune the enclosure to provide what you want.
Generally, it's difficult to change the response of a pre-fab enclosure because the two halves of the enclosure have to be designed to work together.
Sub woofer  helpHide this!Advertise here!
WANTED: 6-7 inch pro mid/woofer or some small box woofer Jimmy154 Swap Meet 10 18th August 2012 01:01 PM
Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer fakeout Multi-Way 5 11th August 2012 07:17 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 03:00 PM
Woofer replacement for Infinity Reference 2000.5 Woofer kchilaka Multi-Way 0 28th September 2010 06:11 AM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 02:30 AM
