Alpine MRX-M110 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 27th August 2014, 03:48 AM   #1
Default Alpine MRX-M110
Anyone know what the part number is for the driver IC's in this ?
All of the outputs are shorted IRFB5615
The drivers IC's are marked
ANAVIEW.COM C1
047P
C B6W5
They are a 16 pin IC and there are 2 of them Not sue on the part number for theese
Anyone know what the part number is or what replacement IC'S will work in this amp?
Old 27th August 2014, 06:02 AM   #2
Perry,
Could this be the driver IC I'm looking for?
http://www.ti.com/lit/ds/slls416b/slls416b.pdf
Old 27th August 2014, 07:14 AM   #3
Unlikely. The IC is probably a proprietary Anaview IC. It may only be available from Alpine.
How did you determine that they were defective?
Old 27th August 2014, 07:43 AM   #4
This amp uses 8 outputs 3 were defective out of. 8
I removed the 3 defective ones and tested the remaining 5 for shorts or leaking..
All tested good I checked all resistors and solder connections all seem fine
I put the. 5 back in the amp and powers it up and it keeps blowing outputs so I'm assuming the driver ic's are defective
Old 27th August 2014, 11:58 AM   #5
Using a current limiter and having the FETs clamped should have prevented blowing the FETs.
Pacparts doesn't have the ICs listed. Contact them to get a price. If they're expensive, I'd spend time checking the ICs more thoroughly (finding the high and low-side supply pins and checking continuity between those pins and the corresponding output pins for the IC).
I've also seen FETs (that were in an amp where other FETs failed) check OK with a meter but fail when driven at high frequency. If the ICs are expensive and they check OK after you find the pins listed above, I'd try a set of new FETs.
Old 7th September 2014, 04:20 AM   #6
Put new outputs in the amp ..
Amp powers up and idlees perfectly I have + - rail voltages
I also have + - 15 volts on the op amps..
Amp has no output at all..
Any ideas on where to go from here?
Old 7th September 2014, 10:38 PM   #7
What is the question that you've been asked for virtually every class D amp that didn't have output?
Old 8th September 2014, 02:25 AM   #8
i do not have rail to rail oscillation ..
Wondeing since i dont have rail to rail oscillation what should i check?
Old 8th September 2014, 03:01 AM   #9
Without a service manual or a datasheet on the driver ICs, I don't have any other suggestions. You may be able to get the service manual from PacParts but there's no guarantee that that will be enough to successfully repair it.
Old 8th September 2014, 04:18 AM   #10
Im gonna call Alpine tommrow and see if the IC's are avaible..
Pins 9 and 10 of 1 IC read 22 ohms between the pins
The other IC that is the same part number reads in the mega ohms
So im guessing that the IC's are defective..
Alpine MRX-V60 scampo77 Car Audio 53 12th February 2014 01:27 PM
Alpine MRX-M240 Fuse Question rickcl Car Audio 7 7th February 2014 05:32 PM
QSC MRX 2450 Panama Dave Solid State 2 15th March 2013 05:04 PM
Help finding Alpine part's for Alpine MRD M1005 paulwall Car Audio 1 19th November 2012 03:46 AM
Copyright 1999-2017 diyAudio
