I don't see any problems there that should cause excessive current draw.
The IC is very likely defective but with the jumper in place, it should allow you to continue troubleshooting to determine what other problems it has.
This amp should power up with a 15 amp ATC/ATO fuse but it may blow the 15 amp small (AGC) glass fuses.
Does it blow the fuse with B+ connected but no remote connected?
