soundstream ref200 S repair - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 9th June 2014, 12:09 PM   #1
Default soundstream ref200 S repair
I'm trying to fix this broken SSref200 S
Q21 and Q22 were shorted so I replaced them with IRFz44's, I read in another thread that they were suitable replacements.
On powering up the amp keeps blowing the internal fuse, I used a 10 amp
D15 and D16 were now testing as failed so I pulled them, I tested them again - off the board and they appear to be fine?
So, I have two questions
I will be replacing D15 and D16 with new components, can anyone tell me the correct order ie is D16 FEP16CT or FEN16CT?
Also why is the amp blowing fuses?
I tested the IRFZ44's and they are fine?
I also tested all the outputs and they are all good
Tested the FEB boards and they are also fine
Thanks in advance
Old 9th June 2014, 12:15 PM   #2
D4 looks like it has been replaced at some stage, does anyone know the correct value, I will replace it for good measure as it's failing diode test
Old 9th June 2014, 12:17 PM   #3
Did you test the drivers before installing the FETs?
If you're looking for subs:
FEP16CT = MUR1620CT
FEN16CT = MUR1620CTR
FEN = D16
If you have a current limiter, power it up through the limiter (all PS transistors clamped and the rectifiers out of the board) and twist the transformer to see if the current draw changes.
Old 9th June 2014, 12:18 PM   #4
1N5402. If that diode is shorted, it would draw excessive current with no remote voltage applied.
Email me if you want the diagram,
babin_perry@yahoo.com
Old 9th June 2014, 12:19 PM   #5
Thanks Perry,
where are the drivers located?
Old 9th June 2014, 12:24 PM   #6
[IMG]Click the image to open in full size.[/IMG]
Old 9th June 2014, 12:30 PM   #7
IN5402 tested fine so I soldered it back in
Old 9th June 2014, 01:04 PM   #8
I tested it with a current limiter and nothing overheats, The yellow protect light is on,
There is no audio.
Also the screw that clamps the board next to the high current switch has a plastic insulating washer, I've never seen these on SS amps?
Old 9th June 2014, 01:20 PM   #9
Apologies- yellow fault light - not protect light
Old 9th June 2014, 01:22 PM   #10
Also found the insulator washer was in the wrong place, google images suggest the plastic washer screw is the one that clamps q21 and q22
soundstream Reference repair vincegironda Car Audio 10 28th May 2014 12:47 AM
Soundstream MC245 repair dhamia Car Audio 3 27th May 2014 11:41 PM
soundstream reference 405 repair POCKETSOUND Car Audio 2 20th March 2013 02:16 AM
Soundstream DA-1 repair downhiller2010 Solid State 1 12th February 2013 01:20 PM
Spice model for REF200 jan.didden Everything Else 1 23rd November 2005 05:49 AM
Copyright 1999-2017 diyAudio
