If the 7570 IC is heating up without producing any drive signals to the output transistors (I'm assuming that the output transistors are in the circuit), I'd suspect that it's defective but I can't recommend that you replace it because I have no direct experience with an amp with these exact symptoms.
If you don't have the service manual, email me for it.
babin_perry@yahoo.com
You need to check the various voltages feeding the IC to confirm that none have greater voltage than they should.
