Skar Audio 4500.1
Does anyone have a high res pic of this driverboard??
As you can see it has been messed with and not sure if the resistors are the correct value..
Simlar driverboards i have here do not have D3A on them but the rest of the driverboard looks very simalar but the values do not match up in the area that been messed with all other values between the driverboards are the same..
So wondering if anyone has a high res pic of this board or possibly can tell me if the values are correct or not..
Put the amp back together without the jumper amp worked fine for. 5 mins then it got stuck in protection mode took the clamps back off the fets and outputs let the amp sit for 15 mins and it powers up and plays perfectly again..
Is that jumper needed on the power supply board or do I have another issue with this amp??
