Thanks for the tip.
For the record, I have installed the BD139 / BD140 combo as the drivers. Does that change your recommendation at all?
I placed an order for the power supply FETs, so I don't have those yet, but I did check the drive signal to this point and thought it looked good.
A couple of questions, this amp has 2K Ohm resistors that look factory installed at R5, R6, R20 & R21 instead of 4.7K. Was that possibly a revision to address that problem?
Should I still change out R6 and R21 since you may have assumed there were 4.7K ohm resistors installed at R5 and R20?
- General Interest
- Car Audio
- Soundstream XXX-6500D - What is the value of R4?
