powerbass asa 2000.1D no output. - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 18th April 2014, 12:09 PM   #1
Default powerbass asa 2000.1D no output.
okay here is the back-story:
i bought this amp off ebay, and found the rail caps and power supply blown. output section appeared okay, but i just tested the outputs, etc. replaced caps and power fets/gate resistors, cleaned up, etc, and powered it up. no protect, rails charged up, etc (can't remember exact voltage, but i can re-check) well, it has no output, so i checked around and found some damage on the driver board. i don't have a schematic, so if someone does, that would be great, thanks. anyways, this is what i found:
q110 and q111: ST2N ?551, st show physical signs of being blown
R173 BURNED
R176 burned
r183 burned
on main board, i found c340 is a 100uf, 100v, which is not original, and i believe it is supposed to be the same as c339, which is 220uf, 100v, based off pics from the other thread by Dr Zeus. may not be important, but i'm not sure of it's purpose. I'm going to test the rest of the driver board components shortly, just figured i would get a jump start.
thank you, -Heath H-
Old 18th April 2014, 01:00 PM   #2
2N5551
R173 = 560 ohms
R176 = 100 ohms
R183 = 10 ohms
I don't know about the 2000 but the 1000 and 1500 have a problem with breaking the legs of the heatsink mounted components. IF you want it to be reliable long term (assuming this wasn't addressed by the manufacturer), you'll need to make supports that sandwich the circuit board between the heatsink and the bottom cover.
Old 18th April 2014, 03:07 PM   #3
thanks, i will have to take that into consideration. do you happen to know that the q110/111 do, or why they have popped like that? like i said, i did a quick check on all the outputs, as usual and they seem to be non-problematic at idle/turn-on, but i want to be prepared so that they do not fail again.
Old 18th April 2014, 03:11 PM   #4
email me
babin_perry@yahoo.com
Old 12th June 2014, 11:32 AM   #5
hi, I have a different problem, basically I would need the wiring diagram, anyone have it? I contacted the PowerBass without answers ...
Powerbass ASA1500.1D mbates14 Car Audio 4 18th June 2014 09:05 PM
Powerbass ASA 1500.10X Dr Zeus Car Audio 8 22nd October 2011 01:55 AM
PowerBass ASA 2000.10 Dr Zeus Car Audio 11 21st December 2010 12:38 AM
PowerBass ASA-600.4 audiobahnkid592 Car Audio 3 19th May 2010 09:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
