Old rockford fosgate punch 150 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 17th March 2014, 08:14 PM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default Old rockford fosgate punch 150
Hey guys im back at this project. It's my old school rockford fosgate punch 150. The problem is the left channel is not working. I remember a while back I replaced NE5532P ic's to see if that would work. The amplifier still powers on and plays through one channel. What do I check? It's missing a driver transistor (D40D8) hard to find those. Has anyone fixed these?
Btw what year is this one from?
Feel the PUNCH
Old 17th March 2014, 08:15 PM   #2
This is the left channel that needs work
Feel the PUNCH
Old 17th March 2014, 08:17 PM   #3
The inside
Feel the PUNCH
Old 17th March 2014, 10:22 PM   #4
rickcl is offline rickcl  United States
Why is that fuse holder empty? For testing?
Old 17th March 2014, 10:39 PM   #5
josesony68's Avatar
You should check, the FET output that faulty channel, to see if they are short, or open, also resistors, capacitors, and check voltages at different points.
I see a fuse missing on that side of the amp, and there is a resistor 1/4 watt, which has a suspicious color ...
I've seen on ebay, a seller who has these transistors (D40D8) and seems reliable.
It is this:
http://www.ebay.es/itm/HARRIS-TO-202...item5655cf0ff3
Old 17th March 2014, 10:53 PM   #6
It is this:
HARRIS TO-202 CASE D40D08 D40D8 TRANSISTOR 2ea FREE USA SHIPPINGnew | eBay
I removed the fuse because that channel had DC on it. I'm guessing maybe just replace all the components in that channel? The outputs are BJT 2N6487 & 2N6490. I can use 2N6491 & 2N6488?
Feel the PUNCH
Old 17th March 2014, 11:04 PM   #7
josesony68's Avatar
If you got DC on the speaker output of the channel, because there is a blown fet, check them.
I prefer to do the replacement, always identical to the original parts of the amplifier.
If you replace those with equivalent FETS, it may not work properly, you have to adjust the bias, or, burn a few minutes ..
Old 17th March 2014, 11:15 PM   #8
They're bipolar transistors? I'm guessing early Fosgate used bipolar outputs in these early amps? Seems a lot different from all the other amps I've worked on..
Feel the PUNCH
Old 17th March 2014, 11:35 PM   #9
josesony68's Avatar
Sorry, if I referred to as FET output transistors, (is the usual,) I think they are just power transistors, "plain" I'm not sure if they are bipolar or not ....
I noticed some time ago a 75HD, but I remember, yes, were mosfet output transistors, specifically IRF 540 or 640'S ....
Anyway, I will repeat, that would try to replace them with the originals, the same channel that is in the works.
Old 18th March 2014, 01:34 AM   #10
WSJ is offline WSJ  United States
WSJ's Avatar
Using the DMM diode test function, check the devices (diodes, NPNs and PNPs) for open in the reverse direction and 600 +/-100 mV in the forward direction. You may need to lift one end of the base emitter resistor or lift the base of each device to get a valid measurement. If they all look good, remove the op amp (on my schematic it’s marked U3) and post a list of all the voltages. Install a socket for U3 incase needs replacing.
I worked for a company who made discrete op amps in 1969 and repaired over 70 amplifiers in one day by troubleshooting with only a DMM. The next day the company shipped over $10,000 worth of op amps. I made $28 a day minus taxes about $17, then the laid me off.
Let me know if you need the schematic.
Rockford Fosgate Punch 150 Pre-HD bastarddsm Car Audio 2 7th March 2014 07:37 PM
Rockford Fosgate Punch 150 mike49504 Car Audio 1 13th June 2012 03:20 AM
Rockford Fosgate Punch 150 mike49504 Car Audio 3 22nd May 2012 03:31 AM
Rockford Fosgate Punch 150 HD's FairfaxStu Car Audio 1 27th May 2010 04:04 AM
Rockford Fosgate Punch 150 HD mike49504 Car Audio 4 17th March 2010 11:22 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
