Nakamichi PA200 upgrades - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th March 2014, 06:14 AM   #1
ishiru is offline ishiru  Indonesia
ishiru's Avatar
Default Nakamichi PA200 upgrades
hello all..
i have Nakamichi PA-200.
previously, i changed all of the electrolytic w/ the better one (i suspected all of them was dried out).
they actually sounds pretty good but kinda dried from my thought.
so changed the pre-driver w/ a mosfet. (i previously changed the original w/ ISC A968/C2238)
the mosfet i used was IRFP240/9240 (i only have them in my shelf)
i was pleased w/ the vocal.they sounds better.but strange!.i heard some distortion on the highs.
i couldn't write how they sounds like but they're pretty audible.no.not pretty audible.but very audible!
is it caused by the mosfet?.does the mosfet was too big?..
oh.i forgot to mention this.originally this amp's bias was very low (i couldn't measure them).and then i re-biased them to 10mV (don't say "that's low!".this amp runs freakin hot after re-bias).
but now after i changed the driver to mosfet the bias back to unmeasured.is this causing the amp has distortion?.this amp before re-bias has no distortion even runs cold.
thanks!
-add-
before i perform this change, i simulated this to LTSpice and got no problem w/ the sinewave
i recorded the video but don't know how to upload it here
iono wat i do
Old 5th March 2014, 07:33 PM   #2
ishiru's Avatar
i figured it out..
i simulated the amp to LTSpice and i figured that when i use mosfet w/ the same bias resistor, the bias goes lower (2.1kOhm bjt was around 3W while mosfet was only 20nW).
i'll try to set the bias pots to around 500Ohm and let's see the bias (yes.when i simulated this amp using mosfet, 495Ohm gave closest result on 2.1kOhm on bjt)
idiot me being idiot
iono wat i do
Nakamichi PA-5 upgrades kotofei Pass Labs 58 16th May 2016 04:40 AM
Upgrades for D1 sixty9 Pass Labs 13 2nd July 2012 09:18 AM
Hickok Upgrades Zero Cool Equipment & Tools 0 22nd June 2008 11:36 PM
Lm3886 Pa200 mrquality Chip Amps 0 26th June 2007 04:36 PM
PA200 and 8ohm load? CJ900RR Chip Amps 9 7th March 2007 04:44 PM
Copyright 1999-2017 diyAudio
