Did I put these back in the correct spots? - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2014, 04:50 PM   #1
90scaraudio's Avatar
Question Did I put these back in the correct spots?
I pulled all the pots off this four band Parametric EQ board to clean them and I thought all of them were 22K. But of course I screwed myself, like normal. OK, I think the gain pots are correct but I'm not sure of the parametric pots.... AAAAHHH. F#@% me running Click the image to open in full size..
I've looked for similar schematics but they are all different.
So I drew one, it only shows the rt channel.
Any help would be greatly appreciated.
Old 6th February 2014, 05:24 AM   #2
ATOMICTECH62 from DIYCARAUDIO answered...
That looks right to me.All the ones Ive seen use lower ohm values on the higher frequencies.I believe they are lower because it makes the Q factor higher.The lower frequencies usually have a lower Q then the higher ones.The only way to be positive though is to go to TI's Filter Pro and start plugging numbers.But that can be time consuming.
If you really want to improve that EQ swap the TL072's for the BB OPA2134's.
I just looked at a Directed 4500 I have and it has 3 200k's for the lower 3 frequencies and a 20k for the high.The caps are different but so are the frequencies.
Did I put these back in the correct spots? 90scaraudio Analog Line Level 2 7th February 2014 05:41 PM
platter black spots won't come off william13 Analogue Source 7 12th July 2012 10:31 PM
Tubes and their sweet spots. ak_47_boy Tubes / Valves 38 15th December 2006 03:42 AM
Copyright 1999-2017 diyAudio
