Power supply for 9KW rms amp and the driver board - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th February 2014, 01:39 AM   #1
Default Power supply for 9KW rms amp and the driver board
Hello! Good day!
I repairing 9KW rms amp and goes to protect mode after blue light.
I removed the DLM4000 driver boards with DLI4060 proprietary IC but still on protect mode.
On this situation, I may say that driver board is not a problem? I know most of the amps powered on even no driver board/s installed? except there's a problem in the main board.
Also do I have sufficient power for my power supply? my power supply is just 6 Amps and 13.6V.
Without load and input signal, is it enough to power this monster amp?
Thank you very much!
Old 5th February 2014, 02:16 AM   #2
ultra's Avatar
Do you measure any DC voltage before the output relays?
Upon powering up, does your power supply voltage increase slowly?
These amps idle around 8 to 9A.
Old 5th February 2014, 02:47 AM   #3
Yes it raise not less than +-60VDC then protects, I think prior relay click protect turn on. I didn't check the voltage yet. Ok ill do that.
But I removed the driver boards already:-(( Can I make it blue light without driver boards?
Old 5th February 2014, 03:26 PM   #4
Tom7227 is offline Tom7227  United States
Tom7227's Avatar
Send a message via AIM to Tom7227
I might have a schematic for that amp, and I was able to purchase the driver pcb's.
Old 5th February 2014, 03:35 PM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
9KW RMS from puny +/-60V rails?
IMPOSSIBLE
Old 5th February 2014, 03:38 PM   #6
JMFahey's Avatar
You-must-be-joking
Old 6th February 2014, 12:34 AM   #7
Originally Posted by JMFahey View Post
You-must-be-joking
I dont know i'm asking...
thats why im here looking for expert and some very nice people around here...
Old 6th February 2014, 12:36 AM   #8
This is good news! can you share your schematics?
Thank you!
Old 6th February 2014, 12:40 AM   #9
ultra's Avatar
You-must-be-joking
9Kw amps like DD Z2, american bass VFL 1000.1 etc, have around +/-168V rail voltage.
Nonprof never said rail voltage was +/-60V.
Old 6th February 2014, 12:40 AM   #10
kevinkr's Avatar
I suspect you need a much bigger power supply.. The idle current in such an amplifier must be greater than the rated current of your supply.
I just can't imagine 9kW, that would require something like 1000A from the car's electrical system.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Amp pcb with on board power supply! jerryo Solid State 10 19th December 2013 12:02 PM
Lateral MOSFET power supply and RMS output power. tallerseverino Solid State 29 25th March 2012 05:32 PM
Sure amp board power supply? emilime75 Class D 2 24th February 2012 12:40 AM
core power ratings for 9kW DCDC stuartsjg Power Supplies 36 19th July 2008 09:57 PM
does someone know the max rms power rating of the Blueprint 1503 driver? pkgum Multi-Way 3 9th December 2001 02:50 PM
Copyright 1999-2017 diyAudio
