Power supply for 9KW rms amp and the driver board - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 6th February 2014, 12:56 AM   #11
Thanks! I will upgrade my power supply!
It's hard for me to troubleshoot this amp, always I call my babysitter to help me to turn the back side of the board.
My wife starting to jealous...
1000A??? a bank of car batteries
thank you so much ultra and kevin!
Old 13th February 2014, 01:57 PM   #12
Cr@sh is offline Cr@sh  United States
Originally Posted by kevinkr View Post
I suspect you need a much bigger power supply.. The idle current in such an amplifier must be greater than the rated current of your supply.
I just can't imagine 9kW, that would require something like 1000A from the car's electrical system.
DB Drag vehicles have exceeded 100kw. Massive battery banks, multiple alternator's. Rockford made 20 15kw amps. My friend has one.
WoofersEtc.com - T15KW - Rockford Fosgate 4 Ch 15,000 Watt Hybrid SQ/SPL Amplifier
One of the largest amps in the world to date.
Old 13th February 2014, 04:02 PM   #13
ultra's Avatar
I think the biggest 12V amp right now is Taramps T20.2/1Ω
Manual states max dissipation at 12.6V is 1890A.
Old 21st February 2014, 03:27 PM   #14
None of the brazilian made amps will do rated rms at 12v, look at the amps powerwire input sizes. Same as all the cactus, Sound digital and the likes. They needed 16-18v to get near rated numbers. Just sayin
Old 30th May 2014, 07:22 PM   #15
ultra's Avatar
I guess there is a bigger amp.
Its from Taramps again, rated for 30Kwrms.
This is a low voltage amp (12V).
Old 30th May 2014, 07:58 PM   #16
They have a 50kw Taramp's Amplificadores
None of there amps will do rated @12v @ 20-80hz even if lightning stuck them, look at the size of the amps? seriously?
PS. It's 126volts dc not 12
see here
https://www.youtube.com/watch?v=0hdplf2bNa8
Amp pcb with on board power supply! jerryo Solid State 10 19th December 2013 12:02 PM
Lateral MOSFET power supply and RMS output power. tallerseverino Solid State 29 25th March 2012 05:32 PM
Sure amp board power supply? emilime75 Class D 2 24th February 2012 12:40 AM
core power ratings for 9kW DCDC stuartsjg Power Supplies 36 19th July 2008 09:57 PM
does someone know the max rms power rating of the Blueprint 1503 driver? pkgum Multi-Way 3 9th December 2001 02:50 PM
Copyright 1999-2017 diyAudio
